Something broken in pppd with rtemsdialer?
    Peter Dufault
    dufault at hda.com
    Tue Nov  1 12:23:46 UTC 2005
I can't build this AM with the same config as before.  I'm bombing
out building cpukit/pppd/auth.c trying to include rtems/
rtemsdialer.h, getting "rtems/rtemsdialer.h: No such file or directory".
pppd/Makefile.am has a misspelling of "rtemsidialer" instead of
"rtemsdialer", but fixing that didn't help.
It looks as if the .am stuff in pppd is trying to get the
rtemsdialer.h into an rtems subdirectory, but it isn't working.  I
notice that libnetworking has an explicit "rtems" subdirectory.
Also, I notice that "backward/rtemsdialer.h" tries to print out a
warning saying to use "rtems/dialer.h", but there isn't any
dialer.h.  I'm guessing this is a work in progress.
Is this a problem with my configuration or is something broken?  This
is Solaris 10 again, and I don't trust it yet.
Peter
(configuration on Opteron Solaris 10 was:
  --target=powerpc-rtems \
     --prefix=/opt/rtems-4.7 \
     --enable-posix \
     --enable-networking \
     --enable-cxx \
     --enable-rtems-debug \
     --disable-itron \
     --enable-maintainer-mode \
     --with-cpu=7450 \
     --enable-rtemsbsp=mvme5500
and tools were verified the other day)
