Problem building Ada examples
Chris Sparks mrada at catalina-inter.net
Tue Nov 8 00:00:48 UTC 2005
Hi Fred,
If you get something working with Ada and RTEMS make sure that it gets
to Joel for inclusion in the baseline.  I am interested in using Ada and
RTEMS myself.
Thanks,
Frédéric PRACA wrote:
>Selon "Joel Sherrill <joel at OARcorp.com>" <joel.sherrill at OARcorp.com>:
>>If memory serves, there should be a start.o in the same directory as the
>>bsp_specs and the above linker options are sufficient to find it.  Is it
>>there?
>First of all, thank you for such a quick answer.
>start.o is in the directory you mentionned.
>>>collect2: ld returned 1 exit status
>>>i386-rtems-gnatlink: cannot call
>>>/home/fred/Dev/Audiome/crossCompiler/binaries/bin/i386-rtems-gcc
>>>i386-rtems-gnatmake: *** link failed.
>>>gmake: *** [hello.exe] Erreur 4
>>>Why does ld look for start.o ????
>>Every program needs start.o which is traditionally known as crt0.o.  It
>>initializes the stack, etc.
>Ok, now I begin to understand.
>Well, I just rebuilt the whole thing and now it works, I think I forgot
>something the first time. I'll try what I compiled with Bochs but it should be
>running.
>Thanks a lot
>Fred
