Cogent 637 board
Camilo Alejandro Arboleda camilo.arboleda at spymac.com
Wed Nov 9 14:16:05 UTC 2005
I'm using GCC 4.0.0, newlib 1.13.  What version should I use? Is there
any work-around?
Joel Sherrill <joel at OARcorp.com> wrote:
> Camilo Alejandro Arboleda wrote:
>> I'm using RTEMS 4.6.99.2. Network driver is loaded, but it seems to
>> fail in the ISR.
>> Linux ethernet driver works fine.
>> I already said that, but I've never worked with ARM before, and I
>> don't know what to look for.
> What gcc version are you using?  There have been cases with gcc 4.0.x
> where something got optimized better and no longer works.
