Cogent 637 board
Jay Monkman jtm at smoothsmoothie.com
Thu Nov 10 03:09:08 UTC 2005
Here's a patch that should fix the problem. Can you try it out and let me know
if works for you?
Did you also have a problem with current_tty in shared/console.c? I had to
modify it to get it to compile.
diff -Naur rtems-4.6.99.2/c/src/lib/libbsp/arm/csb337/network/network.c
rtems-4.6.99.2-fixed/c/src/lib/libbsp/arm/csb337/network/network.c
--- rtems-4.6.99.2/c/src/lib/libbsp/arm/csb337/network/network.c
2005-04-26 18:00:38.000000000 -0500
+++ rtems-4.6.99.2-fixed/c/src/lib/libbsp/arm/csb337/network/network.c
2005-11-09 21:02:38.000000000 -0600
@@ -525,9 +525,11 @@
             /* set the type of mbuf to ifp (ethernet I/F) */
             m->m_pkthdr.rcvif = ifp;
             m->m_nextpkt = 0;
-            /* copy the packet into the cluster pointed to by the mbuf */
-            memcpy((char *)m->m_ext.ext_buf,
+            /* Offset the ethernet header so the IP header will be aligned */
+            m->m_data += 2;
+            memcpy((char *)m->m_data,
                    (char *)(rxbuf_hdrs[sc->rx_buf_idx].address & 0xfffffffc),
                    pktlen);
