multilib question
Till Straumann strauman at slac.stanford.edu
Fri Nov 11 19:51:38 UTC 2005
Paul
Here's my current method (horrible hack - if anybody knows
of a better one, please post it) to find out what multilibs are
going to be built (without having to wait for hours) while tuning
t-rtems. Of course, this doesn't address more complex issues
raised by Ralf (implicit defaults)...
1) gcc/Makefile.in (at the end, add a helper rule):
pmlibs:
        $(GCC_FOR_TARGET) --print-multi-lib
2) configure and build gcc normally first
3) chdir to <build_top>/gcc
4) show/list multilibs:
       make pmlibs
(not much magic, so far but here it comes:)
5) edit/modify t-rtems (in source tree)
6) check what multilibs the new t-rtems would produce:
      chdir <build_top>/gcc
      ./config.status
      make libgcc.mk
      make pmlibs
[(6) is much, much faster than rebuilding everything.]
HTH
-- Till
Paul Whitfield wrote:
>> If your only objective is to reduce the number of multilibs inside of
>> RTEMS, have a look into RTEMS's config-ml.in. There you can filter out
>> multilib variants you're not interested in.
> Thanks Ralf,
> That is indeed all I am was interested in doing..
> With that small pointer I am sure I will be able to figure it out.
> Regards
> Paul.
> The information in this e-mail is intended for the addressee only.
> Unauthorised use, copying, disclosure or distribution by anyone else
> is prohibited. Please let us know immediately if you receive this
> e-mail in error. Thank you.
