Problems with gcc-4.0.1 libstdc++ and mvme5500
Till Straumann strauman at slac.stanford.edu
Thu Nov 17 17:00:22 UTC 2005
Phillip Sorensen wrote:
>  >> I have been trying to get cexp-1.5/RTEMS-GeSys_2.1.beta running on
> the MVME5500 with rtems-4.6.99.2.
>  > How recent is your CVS checkout? I had similar problems and found
> that the linker
>  > script was broken. A few days ago, I committed some changes that let
> mvme5500 use the
>  > script from the 'shared' area which seems to be working.
> Checking out the latest software solved the main problem.  The only
> problem is that the iostream sample know fails to build as part of the
> normal RTEMS build, but I can get it to build later by adding -lstdc++
> to the build.
You should fix the iocstream and cdtest Makefile.am's removing
make-exe (just leaving make-cxx-exe). Hopefully this has been fixed in
CVS already...
T.
> Phil
