Request Example App Reading/Writing Files on Floppy
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Nov 18 20:55:33 UTC 2005
Thomas Doerfler (nt) wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Camilo,
> although floppy drives get a bit outdated, it would still be interesting
> to support them in RTEMS. If you send me your driver code, I might try
> to adapt it to the blkdev architecture.
That would be greatly appreciated Thomas.  I am hoping for a floppy
based system since we will be using a random PC the day of the Pinewood
Derby.  Booting from a floppy and keeping the data files on it keeps
things simpler.
--joel
> wkr,
> Thomas.
> Camilo Alejandro Arboleda schrieb:
>>I have an old PC driver (somewhere). It only works with 1.44 MiB
>>floppies and is pre-blockdev, do you thik it fits your needs?
>>Joel Sherrill <joel at OARcorp.com> wrote:
>>>Hi,
>>>I would appreciate it greatly if someone could send me an example
>>>application for the pc386 BSP that mounts a floppy and accesses files
>>>on it.
>>>I am beginning to reimplement the ancient DOS based software
>>>that our scout troop uses for Pinewood Derby timing.  I would
>>>like to use RTEMS for timing accuracy and want to keep records
>>>on the floppy.
>>>Thanks.
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at:
>      http://www.imd-systems.de/pgpkey_en.html
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.2.5 (MingW32)
> Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
> iD8DBQFDfjDnwHyg4bDtfjQRAhDhAKCSJ8svR8fmeti+OGqCcnJwyXmSXQCdG+hb
> IAzpbutS9xtJ0UEdFuPSkic=
> =+/B0
> -----END PGP SIGNATURE-----
