Request Example App Reading/Writing Files on Floppy
Camilo Alejandro Arboleda
camilo.arboleda at spymac.com
Fri Nov 18 22:22:49 UTC 2005
This driver uses some minix code, I'm not sure about the current
licensing status of those files.
Thomas Doerfler (nt) wrote:
>-----BEGIN PGP SIGNED MESSAGE-----
>Hash: SHA1
>Camilo,
>although floppy drives get a bit outdated, it would still be interesting
>to support them in RTEMS. If you send me your driver code, I might try
>to adapt it to the blkdev architecture.
>wkr,
>Thomas.
>Camilo Alejandro Arboleda schrieb:
>>I have an old PC driver (somewhere). It only works with 1.44 MiB
>>floppies and is pre-blockdev, do you thik it fits your needs?
>>Joel Sherrill <joel at OARcorp.com> wrote:
>>>Hi,
>>>I would appreciate it greatly if someone could send me an example
>>>application for the pc386 BSP that mounts a floppy and accesses files
>>>on it.
>>>I am beginning to reimplement the ancient DOS based software
>>>that our scout troop uses for Pinewood Derby timing. I would
>>>like to use RTEMS for timing accuracy and want to keep records
>>>on the floppy.
>>>Thanks.
>IMD Ingenieurbuero fuer Microcomputertechnik
>Thomas Doerfler Herbststrasse 8
>D-82178 Puchheim Germany
>email: Thomas.Doerfler at imd-systems.de
>PGP public key available at:
> http://www.imd-systems.de/pgpkey_en.html
>-----BEGIN PGP SIGNATURE-----
>Version: GnuPG v1.2.5 (MingW32)
>Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
>iD8DBQFDfjDnwHyg4bDtfjQRAhDhAKCSJ8svR8fmeti+OGqCcnJwyXmSXQCdG+hb
>IAzpbutS9xtJ0UEdFuPSkic=
>=+/B0
>-----END PGP SIGNATURE-----
Type: application/x-gzip
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20051118/d09b9956/attachment.bin>
