Problem rebuilding tools from SRPMs
Steven Johnson sjohnson at sakuraindustries.com
Sun Nov 20 23:27:16 UTC 2005
Hi,
So does anyone have any idea what could be happening to the build from
the SRPM's of the tools?
Because i cant see anything wrong, and it just doesnt work for me.
Steven
Steven Johnson wrote:
> Hi,
> Im trying to rebuild to tools from the SRPMs, and Im striking the
> following error, compiling binutils.
> Im trying to build the PowerPC tools.
> I execute:
> rpmbuild --recompile --rebuild
> rtems-4.6-powerpc-rtems-binutils-collection-2.13.2.1-2.nosrc.rpm
> It starts:
> Installing
> Executing(%prep): /bin/sh -e /var/tmp/rpm-tmp.53621
> + umask 022
> + cd /usr/src/RPM/BUILD
> + rm -rf rtems-4.6-powerpc-rtems-binutils-collection-2.13.2.1
> + /bin/mkdir -p rtems-4.6-powerpc-rtems-binutils-collection-2.13.2.1
> + cd rtems-4.6-powerpc-rtems-binutils-collection-2.13.2.1
> + /usr/bin/bzip2 -dc /usr/src/RPM/SOURCES/binutils-2.13.2.1.tar.bz2
> + tar -xvvf -
> -rw-rw-rw- drow/drow      4658 2002-01-27 08:25:00
> binutils-2.13.2.1/binutils/doc/Makefile.am
> drwxr-xr-x                  Creating directory: binutils-2.13.2.1
> -rw-rw-rw- drow/drow     15549 2002-07-16 13:04:37
> binutils-2.13.2.1/binutils/doc/Makefile.in
> -rw-rw-rw- drow/drow    141091 2002-07-31 05:17:41
> binutils-2.13.2.1/binutils/doc/binutils.texi
> -rw-rw-rw- drow/drow      7539 2002-08-06 07:43:46
> binutils-2.13.2.1/binutils/doc/addr2line.1
> -rw-rw-rw- drow/drow     14859 2002-08-06 07:43:46
> binutils-2.13.2.1/binutils/doc/ar.1
> -rw-rw-rw- drow/drow      2428 2003-01-02 12:25:07
> binutils-2.13.2.1/binutils/doc/binutils.info
> -rw-rw-rw- drow/drow     44267 2003-01-02 12:25:07
> binutils-2.13.2.1/binutils/doc/binutils.info-1
> -rw-rw-rw- drow/drow     49761 2003-01-02 12:25:07
> binutils-2.13.2.1/binutils/doc/binutils.info-2
> -rw-rw-rw- drow/drow     40167 2003-01-02 12:25:07
> binutils-2.13.2.1/binutils/doc/binutils.info-3
> -rw-rw-rw- drow/drow      7944 2002-08-06 07:43:46
> binutils-2.13.2.1/binutils/doc/cxxfilt.man
> -rw-rw-rw- drow/drow     15864 2002-08-06 07:43:46
> binutils-2.13.2.1/binutils/doc/dlltool.1
> -rw-rw-rw- drow/drow      7538 2002-08-06 07:43:46
> binutils-2.13.2.1/binutils/doc/nlmconv.1
> It goes for a while, and then terminates with:
> /var/tmp/rtems-4.6-powerpc-rtems-binutils-collection-2.13.2.1-root/opt/rtems-4.6/info/bfd.info.gz
> /var/tmp/rtems-4.6-powerpc-rtems-binutils-collection-2.13.2.1-root/opt/rtems-4.6/info/binutils.info.gz
> /var/tmp/rtems-4.6-powerpc-rtems-binutils-collection-2.13.2.1-root/opt/rtems-4.6/info/configure.info.gz
> /var/tmp/rtems-4.6-powerpc-rtems-binutils-collection-2.13.2.1-root/opt/rtems-4.6/info/standards.info.gz'
> + test
> 'x/var/tmp/rtems-4.6-powerpc-rtems-binutils-collection-2.13.2.1-root/opt/rtems-4.6/info/as.info.gz
> /var/tmp/rtems-4.6-powerpc-rtems-binutils-collection-2.13.2.1-root/opt/rtems-4.6/info/ld.info.gz
> '!=' x
> + for i in '$f'
> + /sbin/install-info
> /var/tmp/rtems-4.6-powerpc-rtems-binutils-collection-2.13.2.1-root/opt/rtems-4.6/info/dir
> + for i in '$f'
> + for i in '$f'
> + for i in '$f'
> + for i in '$f'
> + for i in '$f'
> Processing files: rtems-4.6-rtems-base-binutils-2.13.2.1-2
> error: File not found by glob:
> /var/tmp/rtems-4.6-powerpc-rtems-binutils-collection-2.13.2.1-root/opt/rtems-4.6/info/binutils.info-?.gz
> /var/tmp/rtems-4.6-powerpc-rtems-binutils-collection-2.13.2.1-root/opt/rtems-4.6/info/ld.info-?.gz
> Processing files: rtems-4.6-powerpc-rtems-binutils-2.13.2.1-2
> RPM build errors:
> Any ideas what i could be doing wrong?
> Im logged in as Root.  I havent changed any paths or anything.
> This is what it built:
> [root at lindev2 SRC]# ls -al
> total 476
> drwxr-xr-x  2 root root  4096 Nov 18 09:58 ./
> drwxr-xr-x  8 root root  4096 Nov 18 09:58 ../
> -rw-r--r--  1 root root 82872 Nov 18 09:58 as.info-1.gz
> -rw-r--r--  1 root root 60620 Nov 18 09:58 as.info-2.gz
> -rw-r--r--  1 root root  3860 Nov 18 09:58 as.info.gz
> -rw-r--r--  1 root root 77361 Nov 18 09:58 bfd.info-1.gz
> -rw-r--r--  1 root root  8141 Nov 18 09:58 bfd.info-2.gz
> -rw-r--r--  1 root root  1278 Nov 18 09:58 bfd.info.gz
> -rw-r--r--  1 root root 38304 Nov 18 09:58 binutils.info.gz
> -rw-r--r--  1 root root 14537 Nov 18 09:58 configure.info-1.gz
> -rw-r--r--  1 root root 14059 Nov 18 09:58 configure.info-2.gz
> -rw-r--r--  1 root root  4186 Nov 18 09:58 configure.info-3.gz
> -rw-r--r--  1 root root  1190 Nov 18 09:58 configure.info.gz
> -rw-r--r--  1 root root  1967 Nov 18 09:58 dir
> -rw-r--r--  1 root root 66089 Nov 18 09:58 ld.info.gz
> -rw-r--r--  1 root root 57331 Nov 18 09:58 standards.info.gz
> So, yes there really isnt any binutils.info-?.gz or ld.info-?.gz files???
> I have makeinfo (GNU texinfo) 4.8 installed on my build system.
> Steven
