RES: Running RTEMS configure script from Eclipse
Fabrício de Novaes Kucinskis fabricio at dea.inpe.br
Wed Nov 23 12:10:36 UTC 2005
Samuel,
I use Eclipse for Linux (Mandrake, in my case), and there's no problem with
this. I just ran a configure script using the "External Tools" feature,
without any problem.
Did you set the parameters in the "External Tools" dialog correctly? Just to
check:
Working Directory: 	[parent-directory-of-your-bsp]
Arguments:			--target=XXXX, etc
Just to illustrate, in my case, it is:
Working Directory: 	/opt
Arguments:			--target=sparc-rtems --enable-bsp=erc32 --prefix=/opt/erc32
I hope this helps.
Regards,
Fabrício.
-----Mensagem original-----
De: Samuel Bitton [mailto:S.Bitton at sstl.co.uk]
Enviada em: quarta-feira, 23 de novembro de 2005 09:06
Para: rtems-users at rtems.com
Assunto: Running RTEMS configure script from Eclipse
Hi
My development environment is based on Eclipse (with CDT) and Cygwin on a
Windows platform.
Has any of you who use similar setting found a way of running the RTEMS
configure script?
I'm trying to do it using the "Running External Tools" functionality but I
get an exception error when the script is launched. I guess that's because
Eclipse is trying to run the configure script as a windows program. I
believe I have to tell Eclipse to run it on Cygwin but can't find how?
Any suggestions?
Thanks
Sam
