Altivec Context Management
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Fri Nov 4 16:25:44 UTC 2005
Ralf Corsepius wrote:
> On Fri, 2005-11-04 at 08:16 -0600, Joel Sherrill wrote:
>>+ Add Altivec multilib
>> If we have extra registers which gcc is aware of, this forces our hand
>> and it adds a multilib.
> We already have this multilib.
> -mcpu=7400 implies altivec, all others don't.
Sorry I missed that piece of knowledge. Then RTEMS should just honor
the __ALTIVEC__ flag which is set when -mcpu=7400 is set. It will
require no tool changes for gcc 4.0.x.
The gcc version for 4.6 does not set __ALTIVEC__ when -mcpu=7400 is
specified.
> I.e. if -maltivec is a problem to RTEMS and some BSPs, you should use a
> different -mcpu=<cpu>. If this is not possible, the powerpc port in
> RTEMS is facing a the limitations of its design.
> IMO, a separate -maltivec multilib variant doesn't make without a major
> redesign of the powerpc port.
It doesn't sound like the multilib variant is needed as long as
-mcpu=7400 is really the correct CPU model CFLAG for the BSPs/CPU models
in question.
But RTEMS does need to honor the __ALTIVEC__ flag and based upon gcc's
use of the vector registers, this would mean it is part of the basic
integer context when available.
>> Whether this should be done for 4.6 tools is up for discussion but it
>> is clear that gcc 4.0.x and newer definitely will have to ship with
>> Altivec multilibs for RTEMS.
> cf. above.
They already do. RTEMS itself just needs to honor Altivec.
Good.. one less piece to deal with.
> Ralf
joel at OARcorp.com On-Line Applications Research
