Cogent 637 board
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Wed Nov 9 14:02:12 UTC 2005
Camilo Alejandro Arboleda wrote:
> I'm using RTEMS 4.6.99.2. Network driver is loaded, but it seems to fail
> in the ISR.
> Linux ethernet driver works fine.
> I already said that, but I've never worked with ARM before, and I don't
> know what to look for.
What gcc version are you using? There have been cases with gcc 4.0.x
where something got optimized better and no longer works.
>>> Have you used the ethernet controller? I get a "data_abort at address
>>> 0x14" error.
>> That's not supposed to happen. :-) It works for me. What version of
>> RTEMS are
>> you using?
joel at OARcorp.com On-Line Applications Research
