Problems with gcc-4.0.1 libstdc++ and mvme5500
Phillip Sorensen
pas37 at cornell.edu
Thu Nov 17 16:56:38 UTC 2005
Till Straumann wrote:
> Phillip Sorensen wrote:
>> I have been trying to get cexp-1.5/RTEMS-GeSys_2.1.beta running on
the MVME5500 with rtems-4.6.99.2.
> How recent is your CVS checkout? I had similar problems and found
that the linker
> script was broken. A few days ago, I committed some changes that let
mvme5500 use the
> script from the 'shared' area which seems to be working.
Checking out the latest software solved the main problem. The only
problem is that the iostream sample know fails to build as part of the
normal RTEMS build, but I can get it to build later by adding -lstdc++
to the build.
Phil
