Problem compiling RTEMS for edb7312
Karel Gardas
kgardas at objectsecurity.com
Thu Nov 24 12:01:26 UTC 2005
On Thu, 24 Nov 2005, Ralf Corsepius wrote:
> I can't reproduce the error, in fact I've built this BSP without any
> problems several times, recently - Last time ca. 60 seconds ago ;)
Cool! So if you are using RTEMS head, you are using recommended and not
hacked GCC toolchain, then probably this issue went away. IIRC I tried
this two or three months ago, using RTEMS head, GCC 4.0.0 (recommended)
toolchain with all RTEMS provided patches (for toolchain) applied.
Cheers,
Karel
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
