Compiling GCC 4.0 for arm-rtems
Camilo Alejandro Arboleda camilo.arboleda at spymac.com
Wed Oct 12 22:42:56 UTC 2005
Hello,
I'm trying (just trying, not success yet) to compile gcc 4.0 (from
ftp.rtems.com) in a windows 2000 box with cygwin, with the following
command:
../../source/gcc-4.0.0/configure --target=arm-rtems --with-gnu-as
--with-gnu-ld --with-newlib --enable-threads
--prefix=/cygdrive/c/cygwin/usr/rtems-4.6/arm-rtems/
--enable-languages=c,c++
but it fails to compile with an error about cpp (I only copy last lines):
configure: loading cache ./config.cache
checking how to run the C++ preprocessor... /lib/cpp
configure: error: C++ preprocessor "/lib/cpp" fails sanity check
See `config.log' for more details.
make: *** [configure-target-libstdc++-v3] Error 1
Looking at config.log, the last lines say:
configure:4544: checking for arm-rtems-nm
configure:4616: checking for arm-rtems-ranlib
configure:4688: checking for arm-rtems-windres
configure:4806: checking whether to enable maintainer-specific portions
of Makefiles
configure:4853: checking if symbolic links between directories work
It's my first time with ARM processor, and I don't know what I'm doing
wrong. Does anybody has experienced this problem?
Thanks for your help,
