mvme2600 netdemo: "
rtwas rtwas at comcast.net
Thu Oct 13 12:01:22 UTC 2005
Hello,
Joel Sherrill <joel at OARcorp.com> wrote:
> rtwas wrote:
>> Hello,
>> I'm still trying to get "netdemo" to work.
> It you don't have the interrupt map, the most it can do is recognize
> the PCI device ID.  It won't work but it is a good sign.
What else do I need to get the interrupts working?
I assume you mean that everything about networking should work find
except it can't answer
interrupts. Is this correct?
In a earlier post:
Joel Sherrill:
 >What CPU is in the mvme260x?  Till.. is it worth making the
 >mvme260x another recognized BSP variant?
Till Straumann:
 >I hope not. Minimal differences should be detected at run-time
 >and not require rebuilding.
It sounds like Till is saying the bsp for the 2307 should handle the
260x variant but
if interrupts are'nt working, I don't see how networking could have ever
worked. If networking
does'nt/has'nt worked, then it seems to me the 260x is not properly
addressed by the 2307 bsp.
Robert W.
