build the source from CVS error
Roger advanceos at 163.com
Fri Oct 14 00:59:58 UTC 2005
Hi Thomas,
     I have installed rtems-4.7-autoconf-rtems-2.59-4
automake-rtems-1.9.6-0 on my host,and run ./bootstrap.
But when I run configure then make all install,the errors appears as follow:
Making all in .
gmake[2]: Entering directory `/embed/cvs-rtems/cvs-build/m68k-rtems/c'
gmake[2]: Nothing to be done for `all-am'.
gmake[2]: Leaving directory `/embed/cvs-rtems/cvs-build/m68k-rtems/c'
Making all in uC5282
gmake[2]: Entering directory `/embed/cvs-rtems/cvs-build/m68k-rtems/c/uC5282'
gmake[2]: *** No rule to make target `all'.  Stop.
gmake[2]: Leaving directory `/embed/cvs-rtems/cvs-build/m68k-rtems/c/uC5282'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/embed/cvs-rtems/cvs-build/m68k-rtems/c'
make: *** [all-recursive] Error 1
Maybe the Cross Compiler Toolset which I install is wrong? I am using
rtems-4.6-m68k-rtems-binutils-2.13.2.1-2.tar.bz2
rtems-4.6-m68k-rtems-gcc-gcc3.2.3newlib1.11.0-4.tar.bz2
rtems-4.6-m68k-rtems-gdb-5.2-1.tar.bz2
rtems-4.6-rtems-base-binutils-2.13.2.1-2.tar.bz2
rtems-4.6-rtems-base-gcc-gcc3.2.3newlib1.11.0-4.tar.bz2
rtems-4.6-rtems-base-gdb-5.2-1.tar.bz2
        Roger
          2005-10-14
