problems with arm - the return
Jay Monkman jtm at smoothsmoothie.com
Fri Oct 21 18:30:22 UTC 2005
Luís Cargnini wrote:
> upload it to the ARM Evaluator 7T and received the above error
> message. question i must pack the rtems application with something ?
> i'm doing what mistake(s) ? i'm based on redboot manual to donwload my
> hello world application and in bare bsp for arm.
What file are you writing to the board? Is it in the right format for your
bootloader? Some bootloaders will deal with ELF files others won't and you need
a binary image. You haven't provided enough information to help you figure this out.
You write that you're using the bare BSP. The bare BSP is just a starting point
so you can write the "real" BSP outside the RTEMS source tree. Did you do that?
