Status of certain include files - rtems cvs
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Mon Oct 24 16:00:01 UTC 2005
Brett Swimley wrote:
> Hi All,
> I'm working with the current CVS sources of rtems, and am curious as to
> why certain include files, notably telnetd.h and pty.h are not
> installed.  With 4.6.x, they were installed in the /lib/include/rtems
> directory.
telnetd is not part of cpukit (yet?) and thus is only installed when you
build for a particular BSP -- not multilib.
Ralf.. the only contents left in c/src/libnetworking are rtems_telnetd
and pppd.  Is it time to consider moving them?
> I am building RTEMS multilib using the following configuration:
> ../rtems-cvs/configure --target=m68k-rtems \
>   --prefix=/opt/rtems \
>   --disable-hwapi \
>   --disable-multiprocessing \
>   --enable-cxx \
>   --disable-rdbg \
>   --disable-tests \
>   --enable-networking \
>   --enable-posix \
>   --disable-itron \
>   --enable-maintainer-mode \
>   --enable-multilib \
> I would like to use the telnet session for some testing, and can't get
> past this problem.
> Is there an additional configuration switch  required to enable some of
> the additional RTEMS tasks to be configured in?
> Regards and TIA,
> Brett Swimley
