Building Ada Cross Compiler following Wiki
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue Oct 25 11:08:28 UTC 2005
ap at rsise.anu.edu.au wrote:
> Hi,
> The Wiki page about Ada and RTEMS mentions compilation of a cross compiler
> failing due to the wrong TARGET value.
> (Note 2, beneath the step for compiling gcc)
> Laurent Guerby was supposedly investigating this bug.
> It seems, newlib provides a dirent.h file in
> newlib-1.13.0/newlib/libc/sys/rtems/sys
> I haven't checked the configuration process yet, but it seems that the
> "rtems" part refers to the architecture of the target, which doesn't get
> included, if the architecture is rtems4.7 or unknown (for the targets
> powerpc-rtems4.7-elf or powerpc-unknown-elf).
> I hope, that helps for whoever is stumbling over this bug, too. - I just
> didn't know, how to get that into the Wiki...
Could you provide information on the gcc version and how you are
configuring and building.
> Cheers,
> Andreas
