Building Ada Cross Compiler following Wiki
Chris Sparks mrada at catalina-inter.net
Tue Oct 25 13:21:18 UTC 2005
Would be nice to be able to use RTEMS and Ada.  I have been on this list
waiting for this to occur.
Joel Sherrill <joel at OARcorp.com> wrote:
> ap at rsise.anu.edu.au wrote:
>> Hi,
>> The Wiki page about Ada and RTEMS mentions compilation of a cross
>> compiler
>> failing due to the wrong TARGET value.
>> (Note 2, beneath the step for compiling gcc)
>> Laurent Guerby was supposedly investigating this bug.
>> It seems, newlib provides a dirent.h file in
>> newlib-1.13.0/newlib/libc/sys/rtems/sys
>> I haven't checked the configuration process yet, but it seems that the
>> "rtems" part refers to the architecture of the target, which doesn't get
>> included, if the architecture is rtems4.7 or unknown (for the targets
>> powerpc-rtems4.7-elf or powerpc-unknown-elf).
>> I hope, that helps for whoever is stumbling over this bug, too. - I just
>> didn't know, how to get that into the Wiki...
> Could you provide information on the gcc version and how you are
> configuring and building.
>> Cheers,
>> Andreas
