MVME5500 board support status?
Peter Dufault dufault at hda.com
Thu Oct 27 19:58:44 UTC 2005
On Oct 27, 2005, at 11:58 AM, Joel Sherrill wrote:
> So you did or did not see it work from CVS (at any time) with gcc
> 4.0.x?
Yes, I did all my work with "powerpc-rtems-gcc (GCC) 4.0.0 20050130
(experimental)", but the rtems CVS is from around June.
>> I'm currently trying to get the cvs head on Solaris, but at a
>> very  low level since other things keep getting in the way.  The
>> last thing  I got was "powerpc-rtems-gcc: new-exceptions/
>> cpu_asm.o: No such file  or directory" building RTEMS even though
>> I'm using:
> If I had to guess on Solaris, I would say it is a shell or m4
> deficiency. Solaris is notorious for having natively provided tools
> that are not robust enough to make autotools happy.
> You could try installing GNU m4 and putting that directory 1st in
> your path.
No, I'm using gnu m4, gnu tar, gnu sed, flex, etc. ahead of the
solaris tools.
Peter
