4.6.5 build error
Jerry Needell jerry.needell at unh.edu
Fri Oct 7 12:45:33 UTC 2005
Joel Sherrill <joel at OARcorp.com> wrote:
> Jerry Needell wrote:
>> OK - here is my first attempt to build rtems-4.6.5 for the sparc. My
>> configuration file is:
>> #! /bin/sh
>> ../rtems-4.6.5/configure  --target=sparc-rtems --disable-posix
>> --disable-itron --enable-tcpip --enable-networking --disable-cxx
>> --enable-tests --enable-rtemsbsp="leon2 leon3  erc32"
>> --prefix=/home/needell/leon/rtems/install
>> The build fails with the following:
>> gmake[4]: Entering directory
>> `/home/needell/leon/rtems/build/b-rtems/sparc-rtems/c/leon2/exec/score'
>> Making all in .
>> gmake[5]: Entering directory
>> mkdir o-optimize
>> gcc32 --pipe -DHAVE_CONFIG_H   -isystem ../../../../leon2/lib/include
>> -D__RTEMS_INSIDE__     -mcpu=cypress -msoft-float  -O2 -g -Wall -ansi
>> -fasm  -o o-optimize/apiext.o -c
>> ../../../../../../rtems-4.6.5/c/src/../../cpukit/score/src/apiext.c
>> cc1: bad value (cypress) for -mcpu= switch
>> gmake[5]: *** [o-optimize/apiext.o] Error 1
>> gmake[5]: Leaving directory
>> gmake[4]: *** [all-recursive] Error 1
>> gmake[4]: Leaving directory
>> gmake[3]: *** [all-recursive] Error 1
>> gmake[3]: Leaving directory
>> `/home/needell/leon/rtems/build/b-rtems/sparc-rtems/c/leon2/exec'
>> gmake[2]: *** [all-recursive] Error 1
>> gmake[2]: Leaving directory
>> `/home/needell/leon/rtems/build/b-rtems/sparc-rtems/c/leon2'
>> gmake[1]: *** [all-recursive] Error 1
>> gmake[1]: Leaving directory
>> `/home/needell/leon/rtems/build/b-rtems/sparc-rtems/c'
>> make: *** [all-recursive] Error 1
>> Any suggestions?  I am puzzlesd by why it is using my native compiler
>> here "gcc32" rather than the cross compiler.
> Doesn't make sense.  How did you configure?  I tested that BSP on two
> different hosts so I don't see why it would do that.
> --joel
At lest I'm not the only one :-)
here are my bin-utils and gcc configuration files.
#! /bin/sh
../binutils-2.13.2.1/configure  --target=sparc-rtems
#! /bin/sh
../gcc-3.2.3/configure  --target=sparc-rtems  --with-gnu-as
--with-newlib --disable-nls --enable-version-specific-runtime-libs
--with-gnu-ld --verbose --enable-languages=c,c++
--enable-threads=rtems  --prefix=/home/needell/leon/rtems/install
- Jerry
