deriving BSP from powerpc/shared
Till Straumann
strauman at slac.stanford.edu
Mon Oct 17 02:20:18 UTC 2005
Ralf Corsepius wrote:
> On Fri, 2005-10-14 at 14:57 -0700, Till Straumann wrote:
>>I have problems with creating a new BSP that inherits from powerpc/shared.
>>In the usual way, the BSP inherits from the shared area by using VPATH
>>and overrides specific files by providing its own version which is found
>>first on VPATH.
> Sorry, I have to disagree: "VPATH is evil", and relying on VPATHS is
> "bad, bad, bad design".
I agree (also with your statement further down about libraries + APIs) -
but it's just the way it is right now...
>>This works fine for C files but the semantics for headers are different:
>>The Makefile.ams in the shared area actually cause some of the shared
>>headers to be installed --> during the 'preinstall' step, the 'shared'
>>headers are installed and *not* the BSP specific ones.
> I don't understand, what you are referring to.
Never mind - I found what I was looking for
[libbsp/powerpc/configure.ac:
AM_CONDITIONAL(need_shared, test "$RTEMS_BSP_FAMILY" =
"motorola_powerpc")]
unless the RTEMS_BSP_FAMILY is listed here, the build process
doesn't descend into the shared subdirs...
T.
> c/src/lib/libbsp/powerpc/shared/Makefile.am on CVS-trunk doesn't install
> anything.
>>Shouldn't the 'shared' area just be a mere repository for files and the
>>'make' process never really build anything in the 'shared' area?
> Well, in an ideal world, there would not be any "shared code", there
> would be libraries, BSPs would like to link into and headers specifying
> APIs.
>>The BSP would then have to explicitely mention all the files it needs/wants
>>and it has complete control.
> That's the current status on CVS-trunk.
>>How would you, Ralf, address this problem?
> By, entirely abandoning shared code and replacing it with libraries with
> a properly defined API.
> Ralf
