Problems compiling rtems to arm
Ralf Corsepius ralf.corsepius at rtems.org
Fri Oct 21 17:05:33 UTC 2005
On Fri, 2005-10-21 at 14:59 -0200, Luís Cargnini wrote:
> Hi,
> someoneknows how to fix this problem:
> arm-rtems-gcc --pipe -B../../../../../lib/
> -B../../../../../arm_bare_bsp/lib/ -specs bsp_specs -qrtems
> -msoft-float   -g -Wall -ansi -fasm         -o o-optimize/pppd.obj
> o-optimize/init.o o-optimize/pppdapp.o
> ../../../../../arm_bare_bsp/lib/no-dpmem.rel
> ../../../../../arm_bare_bsp/lib/no-msg.rel
> ../../../../../arm_bare_bsp/lib/no-mp.rel
> ../../../../../arm_bare_bsp/lib/no-part.rel
> ../../../../../arm_bare_bsp/lib/no-signal.rel
> ../../../../../arm_bare_bsp/lib/no-timer.rel
> ../../../../../arm_bare_bsp/lib/no-rtmon.rel
> /opt/arm-rtems/lib/gcc-lib/arm-rtems/3.2.3/../../../../arm-rtems/bin/ld:
> region FLASH is full (o-optimize/pppd.obj section .text)
> section .fini [00200000 -> 00200003] overlaps section .init [00200000
> -> 00200003]
> section .rodata [00200004 -> 00208ab4] overlaps section .text
> [00200004 -> 0029e533]
> section .data [00208b00 -> 0020c9f3] overlaps section .text [00200004
> -> 0029e533]
> collect2: ld returned 1 exit status
> gmake[5]: *** [o-optimize/pppd.exe] Error 1
> gmake[5]: Leaving directory
> `/home/lvcargnini/puc/mestrado/instramed/rtems/build-rtems/arm-rtems/c/arm_bare_bsp/tests/samples/pppd'
> gmake[4]: *** [all-recursive] Error 1
> gmake[4]: Leaving directory
> `/home/lvcargnini/puc/mestrado/instramed/rtems/build-rtems/arm-rtems/c/arm_bare_bsp/tests/samples'
> gmake[3]: *** [all-recursive] Error 1
> gmake[3]: Leaving directory
> `/home/lvcargnini/puc/mestrado/instramed/rtems/build-rtems/arm-rtems/c/arm_bare_bsp/tests'
> gmake[2]: *** [all-recursive] Error 1
> gmake[2]: Leaving directory
> `/home/lvcargnini/puc/mestrado/instramed/rtems/build-rtems/arm-rtems/c/arm_bare_bsp'
> gmake[1]: *** [all-recursive] Error 1
> gmake[1]: Leaving directory
> `/home/lvcargnini/puc/mestrado/instramed/rtems/build-rtems/arm-rtems/c'
> make: *** [all-recursive] Error 1
The error messages are clear: You're runnning out of memory.
Ralf
