Idle time
leonp at plris.com
leonp at plris.com
Sun Oct 30 19:47:04 UTC 2005
On Sunday, 30 בOctober 2005 20:42, Pavel Pisa wrote:
> On Sunday 30 October 2005 18:17, leonp at plris.com wrote:
> > Hello, all.
> > I should like to measure the CPU free time in my application which runs
> > on MPC860.
> > The obvious way seemed to me to look at the decrementer value each time
> > I enter the idle task, while inside the idle task copy the decrementer
> > value in the loop into intermediate variable. The difference will show
> > how much time the CPU was in the idle task.
> > The problem is, that I do not see any efficient way to do this. The
> > "user extension" mechanism, if I understood it correctly, will add one
> > routine to ALL task switches, thus I shall waste a lot (relatively) of
> > time on a service function.
> > If somebody can advice some more efficient decision, I shall be very
> > glad.
> > Thanks.
> Hello Leon,
> I have next two ideas, which could work.
> Do busy loop in idle which would read time base
> and remember value. If previous value is more
> ancient, than time expected for loop, add the
> time to the busy time accumulator
> long long time_acc=0;
> long long old_time;
> long long new_time;
> old_time=get_time();
> do{
> new_time=get_time();
> if(new_time-old_time>max_expected_loop_time)
> time_acc+=new_time-old_time;
> old_time=new_time;
> }while(1);
May be I do not catch something in your code, but it seems to me that the "if"
clause will work also in the case of task switch and then time_acc will be
incorrect. I thought about the opposite case - if the time between loops is
greater then max_expected_loop_time, then it means that there was task switch
and we mast restart the time counting. But this is too inaccurate...
> Other simpler solution could be to measure number
> of idle loops per second for idle system and use
> it as base for ratio computation if system is loaded.
> The 860 has no MMU and there should not be some big
> jitter resulting from page lookup in the iddle loop.
> It has cache, so the first idle loop round after some activity
> could take little longer and idle loop trashes cache for
> other threads. But both ideas should have many times
> smaller overhead to the real application than some
> extensions hooks.
Although the 860 do has the MMU, this, IMHO, is negligible, and I thought that
this must work, but experiments showed that the error is too much, I was not
able to understand why yet.
> Best wishes
> Pavel Pisa
> e-mail: pisa at cmp.felk.cvut.cz
> www: http://cmp.felk.cvut.cz/~pisa
> work: http://www.pikron.com
Thank you for your reply. I will investigate the second case more deeply - if
you think the same way, it must work...:-)
Dr.Leon M.Pollak
Director
PLR Information Systems Ltd.
