4.6.4 build problems.
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Mon Sep 12 13:18:14 UTC 2005
rtwas wrote:
> Hello,
> I'm not sure how this would apply in my case. I don't run ntp and my
> date and time is fine.
Is the code on a drive that is being accessed across the network?
Just to make sure, I just checked and the time on the machine used to
cut the tarball is correct.  It wouldn't have been impossible for the
date to be off on it.  But it is running ntp so it is unlikely.
--joel
> Robert W.
> Ralf Corsepius wrote:
>> On Sun, 2005-09-11 at 01:25 -0600, rtwas wrote:
>>> Hello,
>>> I have'nt built an RTEMS dist in a while so I always wonder how I'm
>>> gonna screw up.
>>> But this error does'nt seem to be about me:
>>> checking whether build environment is sane... configure: error: newly
>>> created file is older than distributed files!
>>> Check your system clock
>> The error message says all. This normally indicates and ntp-setup
>> problem.
>> Ralf
