_Watchdog_Insert loops infinitely
leonp at plris.com
leonp at plris.com
Tue Sep 13 16:58:43 UTC 2005
Hello, all.
I run into the following very strange problem:
Application runs for about half an hour without a problem. But then it stops
functioning (no communications and processing).
I break into it via the BDM (MPC860) and see that it loops infinitely in the
_Watchdog_Insert function on the file
.../cpukit/score/src/watchdoginsert.c in the
for ( after = _Watchdog_First( header ) ;
after = _Watchdog_Next( after ) ) {
loop. This routine is called by _TOD_Tickle(), which is called by
_Watchdog_Tickle(), which is called by rtems_clock_tick(), which is finally
called by Clock_isr().
The RTEMS version is rather old - rtems-ss-20030703. Host is Linux, the tool
kit is that of the rtems release.
Any help/hint will be highly appreciated.
Leon
