Help! - Compilation error for mips-rtems tools under Cygwin
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Wed Sep 14 20:50:24 UTC 2005
Keith Siders wrote:
> Ralf,
> Can you be a bit more specific? Is this a tools
> configuration issue, a build environment issue, or
> something else altogether?
The RPMs are VERY careful in the configure command they
use. This is configure command generated by RPM for
gcc 4.0.1 on mips-rtems4.7.  It was from a GNU/Linux host.
../gcc-4.0.1/configure --prefix=/opt/rtems-4.7
--bindir=/opt/rtems-4.7/bin --includedir=/opt/rtems-4.7/include
--libdir=/opt/rtems-4.7/lib --mandir=/opt/rtems-4.7/man
--infodir=/opt/rtems-4.7/info --build=i686-pc-linux-gnu
--host=i686-pc-linux-gnu --target=mips-rtems4.7 --with-gnu-as
--with-gnu-ld --with-newlib --verbose --with-system-zlib --disable-nls
--enable-version-specific-runtime-libs --enable-threads=rtems
--enable-languages=c,c++
> Kind regards,
> Keith
> --- Ralf Corsepius <ralf.corsepius at rtems.org> wrote:
>>On Wed, 2005-09-14 at 11:30 -0700, Bruce Robinson
>>wrote:
>>>Keith,
>>>I have a set of scripts I used to build the MIPS
>>tool chain under CYGWIN.
>>>The GCC configuration looks like this:
>>>/opt/gcc/gcc-3.4.1/configure \
>>>  --target=mips-rtems \
>>>  --prefix=/opt/mips-rtems \
>>>  --program-prefix=mips-rtems- \
>>>  --with-local-prefix=/opt/mips-rtems \
>>>  --enable-languages=c \
>>>  --with-gnu-as \
>>>  --with-gnu-ld \
>>>  --with-newlib
>>>If you're interested, e-mail me and I can send you
>>the complete set.
>>I regret having to tell you that you are about to
>>shoot yourself into
>>your foot.
>>Have a look into scripts/gccnewlib/gccnewlib.add to
>>figure out how to
>>configure gcc.
>>Ralf
> __________________________________________________
> Do You Yahoo!?
> Tired of spam?  Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
