PR469 IDE problem, was: Re: Any New 4.6.4 Issues
Angelo Fraietta newsgroups at smartcontroller.com.au
Fri Sep 16 03:56:33 UTC 2005
Ralf Corsepius wrote:
> On Fri, 2005-09-16 at 08:18 +1000, Angelo Fraietta wrote:
>>cp: $1/install-sh: No such file or directory
> This $1 is strange. Which shell are you using?
bash on OSX
>>configure.ac: installing `$1/install-sh'
>>configure.ac:     error while copying
>>cp: $1/mkinstalldirs: No such file or directory
>>configure.ac: installing `$1/mkinstalldirs'
>>cp: $1/missing: No such file or directory
>>configure.ac: installing `$1/missing'
>>aclocal.m4:28: require version 1.7.2, but have 1.6.3
> You are using the wrong version of automake.
I have that chugging away now after installing new autoconf and automake
While I am waiting for it to finish bootstrap, I can discuss a new
problem with this build
Before applying this patch, I decided to build my application with 4.6.4
as it stands now before attempting to fix the ATA
My configure was
--target=i386-rtems --prefix=/opt/rtems \
    --enable-cxx --disable-tests --enable-networking \
    --enable-posix --enable-itron
When I try to build my app, I get the following error
make: *** No rule to make target
`/opt/rtems/lib/gcc-lib/i386-rtems/3.2.3/include/c++/deque', needed by
`o-optimize/baseshel.o'.  Stop.
I assume this means that I have to define something in my makefile or
configure. Any suggestions
> Ralf
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.smartcontroller.com.au/~angelo/
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
     Bernard of Clairvaux (1090 - 1153)
