RTEMS and PC/104, PC/104+
Angelo Fraietta newsgroups at smartcontroller.com.au
Fri Sep 16 23:37:21 UTC 2005
Dusatko, John E. wrote:
> Hello,
> Has anyone developed or used RTEMS for the PC/104 or PC/104+ platforms and if so, which ones (CPU, board company, etc.)?
I have and just tested the IDE on the secondary slave with a compact
flash and it works.
http://www.smartcontroller.com.au/~angelo/CM587/Manual/CM587.pdf
Just need to get the ethernet drivers now
They provide the Linux source, which you can see at
http://www.smartcontroller.com.au/~angelo/CM587/Driver/Lan/unix/redhat6.2/linux-2.2.x
Someone said they were going to implement the rt18139, however, they
never got back with an example exe
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
     Bernard of Clairvaux (1090 - 1153)
