IDE Works: was Re: PR469 IDE problem, was: Re: Any New 4.6.4 Issues
    Angelo Fraietta
    newsgroups at smartcontroller.com.au
    Fri Sep 16 23:43:44 UTC 2005
Angelo Fraietta wrote:
> I did a make, then changed the file
> Then I did a make depend
> then a make again. It appears that the changed .h file was picked up.
It is a success - Tested it out on the PC104 card and was able to read
and write to the compact flash.
The way I have it implemented is that I have it as a different BSP to my
DIMMPC (which is pc386dx -- this one is PC386). I can see how one could
use it still using the RTEMS makefile by doing a configure with a
different prefix if wanted to use the same BSP.
This is a big stepping stone to having this PC104 board fully RTEMS
capable (I suppose that is a different subject)
Just need to get the ethernet drivers now
The manufacturer provide the Linux source, which you can see at
http://www.smartcontroller.com.au/~angelo/CM587/Driver/Lan/unix/redhat6.2/linux-2.2.x
Someone said they were going to implement the rt18139, however, they
never got back with an example exe
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
     Bernard of Clairvaux (1090 - 1153)
