PR649, was Re: PR469 IDE problem, was: Re: Any New 4.6.4 Issues
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Mon Sep 19 13:09:02 UTC 2005
Thomas Doerfler (nt) wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Angelo,
> thank you for your feedback, I am glad the patch fixes your problem.
> To all: when I renamed this discussion to "PR469...", I have taken the
> wrong PR number as reference, so the actual PR number fixed is PR649,
> not PR469.
> wkr,
> Thomas
>>>../configure --enable-rtemsbsp=pc386 \
>>>- --target=i386-rtems4.7 \
>>>- --prefix=<whatever> \
>>>IDE_USE_PRIMARY_INTERFACE=0 \
>>>IDE_USE_SECONDARY_INTERFACE=1
>>>Angelo, can you try this out?
>>Just did. I made this one pc586 and configured as you said.
>>Worked fine. I also looked in the bspopts.h file and it was written in
>>there. I then ran on PC104 and it worked
Too much driving this weekend lead me to a slightly modified way of
turning on and off the two IDE interfaces.
Some BSPs have variables in the linkcmds which can be overridden at link
time.  It is often used for setting RamSize.  Would this be a good
candidate for this technique?
--joel
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at:
>      http://www.imd-systems.de/pgpkey_en.html
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.2.5 (MingW32)
> Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
> iD8DBQFDK6x6wHyg4bDtfjQRAmmoAJsHvgubxpqV90QjpYTxcR/jcbYBvACfXlj8
> tSBUok/UsvOyYA+KitGapHE=
> =AWgY
> -----END PGP SIGNATURE-----
