mvme2600/4 motorola_bsp: Anyway doing work on this bsp?
rtwas rtwas at comcast.net
Sat Sep 24 21:12:11 UTC 2005
Hello,
 >Hi Robert
 >I understand your frustration.
 >However, the information you provide is not detailed enough
 >to get a picture about what's happening.
Sorry, I had'nt realized you were trying to help me with making
230x work right.
 >- what exactly are you trying to run, i.e., what application,
 From the examples: "hello_world"
 >  what version of RTEMS etc.
4.6.2
 >- when you experience 'segfaults' do you get any register
 >  dumps or other messages?
PPC1-Bug>nbo
Network Booting from: DEC21140, Controller 0, Device 0
Device Name: /pci at 80000000/pci1011,9 at e,0:0,0
Loading: 2604-0.boot
Client IP Address      = 192.168.1.61
Server IP Address      = 192.168.1.60
Gateway IP Address     = 192.168.1.60
Subnet IP Address Mask = 255.255.255.0
Boot File Name         = 2604-0.boot
Argument File Name     =
Network Boot File load in progress... To abort hit <BREAK>
Bytes Received =&153644, Bytes Loaded =&153644
Bytes/Second   =&76822, Elapsed Time =2 Second(s)
Exception: Program (Illegal Instruction)
SRR0 =00000024 SRR1 =00083040 Vector-Offset =00700
IP     =00000024 MSR    =00003040 CR     =48400000 FPSCR  =00000000
R0     =00000000 R1     =001F0190 R2     =00000000 R3     =00000000
R4     =001F0000 R5     =0002582C R6     =00000020 R7     =00000028
R8     =001F0028 R9     =00000000 R10    =00000000 R11    =001F0000
R12    =002117C8 R13    =00023F80 R14    =00000000 R15    =00000000
R16    =00000000 R17    =00000000 R18    =00000000 R19    =00000000
R20    =00000000 R21    =00000000 R22    =00000000 R23    =00000000
R24    =00000000 R25    =00000000 R26    =00000000 R27    =00000000
R28    =00003040 R29    =00000080 R30    =0002944C R31    =00000000
SPR0   =00000000 SPR1   =20000000 SPR8   =000004DC SPR9   =00009600
00000024 00000000  WORD        $00000000
PPC1-Bug>
 >- please attach a console log, your env settings, ...
PPC1-Bug>env
Bug or System environment [B/S] = B?
Field Service Menu Enable [Y/N] = N?
Remote Start Method Switch [G/M/B/N] = B?
Probe System for Supported I/O Controllers [Y/N] = Y?
Auto-Initialize of NVRAM Header Enable [Y/N] = Y?
Network PReP-Boot Mode Enable [Y/N] = N?
Negate VMEbus SYSFAIL* Always [Y/N] = N?
SCSI Bus Reset on Debugger Startup [Y/N]   = N?
Primary SCSI Bus Negotiations Type [A/S/N] = A?
Primary SCSI Data Bus Width [W/N]          = N?
Secondary SCSI Identifier                  = "07"?
NVRAM Bootlist (GEV.fw-boot-path) Boot Enable [Y/N]           = N?
NVRAM Bootlist (GEV.fw-boot-path) Boot at power-up only [Y/N] = N?
NVRAM Bootlist (GEV.fw-boot-path) Boot Abort Delay            = 5?
Auto Boot Enable [Y/N]           = N?
Auto Boot at power-up only [Y/N] = N?
Auto Boot Scan Enable [Y/N]      = Y?
Auto Boot Scan Device Type List  = FDISK/CDROM/TAPE/HDISK/?
Auto Boot Controller LUN   = 00?
Auto Boot Device LUN       = 00?
Auto Boot Partition Number = 00?
Auto Boot Abort Delay      = 7?
Auto Boot Default String [NULL for an empty string] = ?
ROM Boot Enable [Y/N]            = N?
ROM Boot at power-up only [Y/N]  = Y?
ROM Boot Enable search of VMEbus [Y/N] = N?
ROM Boot Abort Delay             = 5?
ROM Boot Direct Starting Address = FFF00000?
ROM Boot Direct Ending Address   = FFFFFFFC?
Network Auto Boot Enable [Y/N]           = N?
Network Auto Boot at power-up only [Y/N] = N?
Network Auto Boot Controller LUN = 00?
Network Auto Boot Device LUN     = 00?
Network Auto Boot Abort Delay    = 5?
Network Auto Boot Configuration Parameters Offset (NVRAM) = 00001000?
Memory Size Enable [Y/N]         = Y?
Memory Size Starting Address     = 00000000?
Memory Size Ending Address       = 02000000?
DRAM Speed in NANO Seconds       = 60?
ROM First Access Length (0 - 31) = 10?
ROM Next Access Length  (0 - 15) = 0?
DRAM Parity Enable [On-Detection/Always/Never - O/A/N]    = O?
L2Cache Parity Enable [On-Detection/Always/Never - O/A/N] = O?
PCI Interrupts Route Control Registers (PIRQ0/1/2/3) = 0A0B0E0F?
Serial Startup Code Master Enable [Y/N] = N?
Serial Startup Code LF Enable [Y/N] =     N?
VME3PCI Master Master Enable [Y/N] = Y?
PCI Slave Image 0 Control                = 00000000?
PCI Slave Image 0 Base Address Register  = 00000000?
PCI Slave Image 0 Bound Address Register = 00000000?
PCI Slave Image 0 Translation Offset     = 00000000?
PCI Slave Image 1 Control                = 00000000?
PCI Slave Image 1 Base Address Register  = 01000000?
PCI Slave Image 1 Bound Address Register = 20000000?
PCI Slave Image 1 Translation Offset     = 00000000?
PCI Slave Image 2 Control                = 00000000?
PCI Slave Image 2 Base Address Register  = 20000000?
PCI Slave Image 2 Bound Address Register = 22000000?
PCI Slave Image 2 Translation Offset     = D0000000?
PCI Slave Image 3 Control                = 00000000?
PCI Slave Image 3 Base Address Register  = 2FFF0000?
PCI Slave Image 3 Bound Address Register = 30000000?
PCI Slave Image 3 Translation Offset     = D0000000?
VMEbus Slave Image 3 Control                = 00000000?
VMEbus Slave Image 3 Base Address Register  = 00000000?
VMEbus Slave Image 3 Bound Address Register = 00000000?
VMEbus Slave Image 3 Translation Offset     = 00000000?
PCI Miscellaneous Register       = 10000000?
Special PCI Slave Image Register = 00000000?
Master Control Register          = 80C00000?
Miscellaneous Control Register   = 52060000?
User AM Codes                    = 00000000?
PPC1-Bug>
Thanks.
Robert W.
