mvme2600/4 motorola_bsp: Anyway doing work on this bsp?
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Sun Sep 25 19:42:01 UTC 2005
rtwas wrote:
> Till Straumann wrote:
>>> Network PReP-Boot Mode Enable [Y/N] = N?
>> One thing - I believe the (admittedly well hidden
>> c/src/lib/libbsp/powerpc/motorola_powerpc/BOOTING
>> file -- I had a hard time figuring this out a couple of
>> years ago and I agree that this is not first-time user
>> friendly) says that you have to enable PreP mode
>> Network PReP-Boot Mode Enable [Y/N] = Y?    <====================
>> HTH
>> --Till
> I made the change specified and...
> PPC1-Bug>nbo
> Network Booting from: DEC21140, Controller 0, Device 0
> Device Name: /pci at 80000000/pci1011,9 at e,0:0,0
> Loading: 2604-0.boot
> Client IP Address      = 192.168.1.61
> Server IP Address      = 192.168.1.60
> Gateway IP Address     = 192.168.1.60
> Subnet IP Address Mask = 255.255.255.0
> Boot File Name         = 2604-0.boot
> Argument File Name     =
> Network Boot File load in progress... To abort hit <BREAK>
> Bytes Received =&153644, Bytes Loaded =&153644
> Bytes/Second   =&76822, Elapsed Time =2 Second(s)
> Residual-Data Located at: $01F78000
> M
> B
> T
> i
> M
> H
> Model: 000000000000000000000000000(e2)
> Serial: MOT0325F15
> Processor/Bus frequencies (Hz): 199922336/66636112
> Time Base Divisor: 4000
> Memory Size: 2000000
> Original MSR: 3040
> Original HID0: 80
> Original R31: 0
> PCI: Probing PCI hardware
> RTEMS 4.x/PPC load:
> Uncompressing the kernel...
> Kernel at 0x00000000, size=0x36f60
> Initrd at 0x00000000, size=0x0
> Residual data at 0x00037000
> Command line at 0x0003e000
> done
> Now booting...
> Welcome to rtems-4.6.2(PowerPC/PowerPC 604/mvme2307) on MVME 2600 with
> MVME712M
> OpenPIC found at C1000000.
> pci : Interrupt routing not available for this bsp
> OpenPIC Version 1.2 (2 CPUs and 17 IRQ sources) at 0xC1000000
> OpenPIC Vendor 0 (Motorola), Device 0 (Raven), Stepping 1
> OpenPIC timer frequency is 8329514 Hz
> Please add code for PCI/ISA bridge init to
> libbsp/powerpc/shared/irq/irq_init.c
> If your card works correctly please add a test and set
> known_cpi_isa_bridge to e
> currentBoard = 15
> Universe II PCI-VME bridge detected at 0xC1041000, IRQ 11
> Universe Master Ports:
> Port  VME-Addr   Size       PCI-Adrs   Mode:
> 0:    0x20000000 0x0F000000 0x10000000 A32, Dat, Sup
> 1:    0x00000000 0x00FF0000 0x1F000000 A24, Dat, Sup
> 2:    0x00000000 0x00010000 0x1FFF0000 A16, Dat, Sup
> Universe Slave Ports:
> 0:    0xC0000000 0x01FE0000 0x80000000 A32, Pgm, Dat, Sup, Usr
> Overriding main IRQ line PCI info with 5
> )egistering /dev/console as minor 0 (==/dev/ttyS0)
> *** HELLO WORLD TEST ***
> Hello World
> *** END OF HELLO WORLD TEST ***
YEAH!!! Can you please make sure the mvme260x gets added to the
Wiki?
What CPU is in the mvme260x?  Till.. is it worth making the
mvme260x another recognized BSP variant?
> ..Robert does a happy dance..
> Thank you very much. :)
> Robert W.
