mvme2600/4 motorola_bsp: Anyway doing work on this bsp?
Till Straumann strauman at slac.stanford.edu
Mon Sep 26 17:21:22 UTC 2005
Joel Sherrill <joel at OARcorp.com> wrote:
> rtwas wrote:
>> Till Straumann wrote:
>>>> Network PReP-Boot Mode Enable [Y/N] = N?
>>> One thing - I believe the (admittedly well hidden
>>> c/src/lib/libbsp/powerpc/motorola_powerpc/BOOTING
>>> file -- I had a hard time figuring this out a couple of
>>> years ago and I agree that this is not first-time user
>>> friendly) says that you have to enable PreP mode
>>> Network PReP-Boot Mode Enable [Y/N] = Y?    <====================
>>> HTH
>>> --Till
>> I made the change specified and...
>> PPC1-Bug>nbo
>> Network Booting from: DEC21140, Controller 0, Device 0
>> Device Name: /pci at 80000000/pci1011,9 at e,0:0,0
>> Loading: 2604-0.boot
>> Client IP Address      = 192.168.1.61
>> Server IP Address      = 192.168.1.60
>> Gateway IP Address     = 192.168.1.60
>> Subnet IP Address Mask = 255.255.255.0
>> Boot File Name         = 2604-0.boot
>> Argument File Name     =
>> Network Boot File load in progress... To abort hit <BREAK>
>> Bytes Received =&153644, Bytes Loaded =&153644
>> Bytes/Second   =&76822, Elapsed Time =2 Second(s)
>> Residual-Data Located at: $01F78000
>> M
>> B
>> T
>> i
>> M
>> H
>> Model: 000000000000000000000000000(e2)
>> Serial: MOT0325F15
>> Processor/Bus frequencies (Hz): 199922336/66636112
>> Time Base Divisor: 4000
>> Memory Size: 2000000
>> Original MSR: 3040
>> Original HID0: 80
>> Original R31: 0
>> PCI: Probing PCI hardware
>> RTEMS 4.x/PPC load:
>> Uncompressing the kernel...
>> Kernel at 0x00000000, size=0x36f60
>> Initrd at 0x00000000, size=0x0
>> Residual data at 0x00037000
>> Command line at 0x0003e000
>> done
>> Now booting...
>> Welcome to rtems-4.6.2(PowerPC/PowerPC 604/mvme2307) on MVME 2600
>> with MVME712M
>> OpenPIC found at C1000000.
>> pci : Interrupt routing not available for this bsp
>> OpenPIC Version 1.2 (2 CPUs and 17 IRQ sources) at 0xC1000000
>> OpenPIC Vendor 0 (Motorola), Device 0 (Raven), Stepping 1
>> OpenPIC timer frequency is 8329514 Hz
>> Please add code for PCI/ISA bridge init to
>> libbsp/powerpc/shared/irq/irq_init.c
>> If your card works correctly please add a test and set
>> known_cpi_isa_bridge to e
>> currentBoard = 15
>> Universe II PCI-VME bridge detected at 0xC1041000, IRQ 11
>> Universe Master Ports:
>> Port  VME-Addr   Size       PCI-Adrs   Mode:
>> 0:    0x20000000 0x0F000000 0x10000000 A32, Dat, Sup
>> 1:    0x00000000 0x00FF0000 0x1F000000 A24, Dat, Sup
>> 2:    0x00000000 0x00010000 0x1FFF0000 A16, Dat, Sup
>> Universe Slave Ports:
>> 0:    0xC0000000 0x01FE0000 0x80000000 A32, Pgm, Dat, Sup, Usr
>> Overriding main IRQ line PCI info with 5
>> )egistering /dev/console as minor 0 (==/dev/ttyS0)
>> *** HELLO WORLD TEST ***
>> Hello World
>> *** END OF HELLO WORLD TEST ***
> YEAH!!! Can you please make sure the mvme260x gets added to the
> Wiki?
> What CPU is in the mvme260x?  Till.. is it worth making the
> mvme260x another recognized BSP variant?
I hope not. Minimal differences should be detected at run-time
and not require rebuilding.
T.
>> ..Robert does a happy dance..
>> Thank you very much. :)
>> Robert W.
