Problem when trying to build hello_world_c
Fabrício de Novaes Kucinskis
fabricio at dea.inpe.br
Tue Sep 27 19:28:17 UTC 2005
Hi all,
I was using RTEMS 4.0.0, and just upgraded to the 4.6.4 release. In the
4.0.0 version, I built applications using sparc-rtems-gcc with the "-rtems"
switch.
After install binutils, gcc, newlib, gdb, and build the RTEMS, I tried to
build a sample program (hello_world_c) to test the instalation, but I the
gcc compiler didn't recognized the "-rtems" switch. I found that it isn't
suported anymore.
So, I tried to use make, but got this error message:
Makefile:33: /Makefile.inc: No such file or directory
Makefile:35: no file name for `include'
Makefile:36: /make/leaf.cfg: No such file or directory
make: *** No rule to make target `/make/leaf.cfg'. Stop.
I'm sure that the RTEMS_MAKEFILE_PATH is pointing to the right directory.
What can be happening?
Thanks in advance,
Fabrício de Novaes Kucinskis - DEA / INPE
Divisão de Eletrônica Aeroespacial
Instituto Nacional de Pesquisas Espaciais
