RTEMS simple example
Aleix Conchillo Flaque aconchillo at ieec.fcr.es
Fri Sep 30 07:34:13 UTC 2005
Joel Sherrill said:
> Neat.  Would you mind if it got merged into RTEMS examples?
Of course not. That would be great! I've used the GPL license, so no problem.
> You might want to consider adding a simple menu to the bottom of the
> Init task which lets you print out the CPU usage or generate a stack
> report if you have that turned on.
Yes, that would be a nice addition. I'll try to add it when I have a
little time.
> The ERC32 specific addresses is easy to solve.  We have this issue on
> the RTEMS tests and solve it by declaring an array that is the memory
> so the linker can easily account for it.  It's just a test/demo so not
> a problem.  This is a hack at changing this.
[snip]
Thanks! I've just applied the patch. Then, I think the example should work
on any system, could anyone try it?
By the way, you can get the sources in the same URLs.
Thanks for everything.
Best regards,
aleix
Aleix Conchillo Flaque   Software Engineer
aconchillo at ieec.fcr.es   Institut d'Estudis Espacials de Catalunya (IEEC)
                         http://www.ieec.fcr.es
