RES: Strange behavior when running RTEMS on an ERC32 chipset Tharsys board
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Sep 9 14:16:30 UTC 2005
Fabrício de Novaes Kucinskis wrote:
> Jiri,
> Thank you very much for the explanation! I was sure that a trap was
> happening and overwriting the trap table, but I could not find what trap,
> nor the reason!
> I didn't realize that "mov %gX, %tbr" is a synthetic instruction, and it is,
> in fact, a "wrtbr", which is a privileged instruction! And because there is
> a "ta 0" in the address of the trap type "privileged instruction", the TBR
> continues to show me that the last trap ocurred is Ticc (the same as before
> the TBR is set), not a privileged instruction. Now everything is clear!
I thought Jiri's discussion deserved to be Wiki'ed.  It is now at
http://www.rtems.com/wiki/index.php/SparcBSPStartup and linked to by the
Erc32 BSP.  The other SPARC BSPs should link there was well.
Please feel free to add any comments or corrections, you think are needed.
--joel
> Thank you again!
> Best regards,
> Fabrício.
> -----Mensagem original-----
> De: Jiri Gaisler [mailto:jiri at gaisler.com]
> Enviada em: quinta-feira, 8 de setembro de 2005 20:44
> Para: joel.sherrill at OARcorp.com
> Cc: Fabrício de Novaes Kucinskis; RTEMS - Mailing List
> Assunto: Re: Strange behavior when running RTEMS on an ERC32 chipset
> Tharsys board
> This is not a bug. The whole process is somewhat complex
> to explain though. So here we go ...
> 1. The sparc port of rtems generates binaries that do
>     not perform any board initialisation, and that are
>     linked to the begining of the RAM. The idea behind
>     this is to avoid having a separate bsp for every
>     possible board around. Instead, a boot-prom builder
>     (mkprom) is used to create a selft-extracting prom
>     image that initialises all board registers, loads the
>     application to ram, and the starts it. The parameters
>     to mkprom defines memory sizes, waitstates, frequency
>     stack pointer and so on. So far so good...
> 2. When running on a (recent) erc32 simulator, the rtems
>     image is loaded into the emulated ram and started from
>     there. The simulator detects that the start address is
>     not 0 (sparc reset vector) and perform the necessary
>     board init routines that would have been make by mkprom
>     on real hardware.
> 3. An issue with the 3-chip version of ERC32 is that the
>     timer scaling register can not be read, only written (!).
>     The rtems application can therefore not read the timer
>     scaler to figure out which frequency the board is running
>     at. To solve this, both the mkprom loader and the simulator
>     writes a copy of the scaler value to trap entry 0x7e in
>     the sparc trap table, because this trap can never occur
>     anyway. The rtems application picks up the value from
>     there and now knows the frequency and can generate proper
>     timer events etc.
> 4. Possible cause of the problem: Fabrício could be running rdbmon
>     debug monitor on his board, using it to download and start
>     applications. rdbmon is an application on its own, and needs
>     to insert its trap vectors into the rtems applications
>     trap table. This is done by starting the application in
>     user mode. The first priviledged instruction that occurs
>     is a write to %tbr (trap base register). This instruction
>     will trap and control is transfered to rdbmon. The monitor
>     can read out the value of the new %tbr, insert its trap
>     entries there, write the scaler value in 0x7e of the new
>     trap table, and re-start the application is supervisor mode.
>     What can not be done (and this is also mentioned in the
>     leccs/rdbmon manual) is to single step through this
>     procedure. What can also not be done is to use a custom
>     loader that does not write 0x7e, or custom start up code
>     that re-allocates the trap table.
> Note that these issues are commented in start.S and spurious.c
> of the sparc/erc32 bsp.
> start.S
>     This is a sad patch to make sure that we know where the
>     MEC timer control register mirror is so we can stop the timers
>     from an external debugger. It is needed because the control
>     register is write-only. Trap 0x7C cannot occur in ERC32...
>     We also use this location to store the last location of the
>     usable RAM in order not to overwrite the remote debugger with
>     the RTEMS work-space area.
> 	.global SYM(_ERC32_MEC_Timer_Control_Mirror), SYM(rdb_start),
> SYM(CLOCK_SPEED)
> 	.global SYM(Configuration)
> SYM(rdb_start):
> SYM(_ERC32_MEC_Timer_Control_Mirror):
>    BAD_TRAP; BAD_TRAP;                           ! 7C - 7D undefined
> SYM(CLOCK_SPEED):
>    .word	0x0a, 0, 0, 0				! 7E (10 MHz default)
> spurious.c
>    for ( trap=0 ; trap<256 ; trap++ ) {
>       *  Skip window overflow, underflow, and flush as well as software
>       *  trap 0 which we will use as a shutdown. Also avoid trap 0x70 - 0x7f
>       *  which cannot happen and where some of the space is used to pass
>       *  paramaters to the program.
>       if (( trap == 5 || trap == 6 ) ||
>       	(( trap >= 0x11 ) && ( trap <= 0x1f )) ||
>       	(( trap >= 0x70 ) && ( trap <= 0x83 )))
>        continue;
>      set_vector( (rtems_isr_entry) bsp_spurious_handler,
>           SPARC_SYNCHRONOUS_TRAP( trap ), 1 );
> Joel Sherrill <joel at OARcorp.com> wrote:
>>What version of RTEMS is this with?  I was seeing an issue today with
>>the CVS head on SIS.  It turned out that the start.s code is copying
>>initialized data from ROM to RAM but I didn't see anywhere in the
>>linkcmds where the initialized data was actually placed there.
>>Commenting out "copy_data" loop fixed it.
>>Can anybody comment on what sections need to be added to the
>>linkcmds to make this work?
>>-joel
>>>I'm working with a Tharsys board with a ERC32 chipset (TSC691E + TSC69È +
>>>TSC69É), and I noticed a very strange behavior when the RTEMS is being
>>>initialized.
>>>When trying to execute the example program "rtems-task" in the board, the
>>>RTEMS freezes for some seconds, and then the watchdog timer resets the
>>>board.
>>>After many hours of debugging, I discovered that the problem occurs
>>>when the
>>>RTEMS tries to read _ CLOCK_SPEED, stored in the address 0x020007e0.
>>>This
>>>address is in the trap table area of the ERC32.
>>>At the moment where the RTEMS tries to read this value, what is
>>>written in
>>>this position of memory is not the clock value, but the instruction
>>>"ta 0".
>>>What I noticed was that, in the first instructions of the RTEMS, the Trap
>>>Base Register (TBR) is configured. At this moment, some addresses of the
>>>trap table have its routines modified, including the address of
>>>_CLOCK_SPEED.
>>>What I don't understand is that the overlapping of trap table occurs
>>>in the
>>>execution of the instruction that modifies the TBR, what for me
>>>doesn't make
>>>sense. I verified the system registers, and none trap occurred at this
>>>moment.
>>>It is important to notice that this problem doesn't happen in the Sparc
>>>Instruction Simulator.
>>>I solved the problem with a small patch, rewriting the address _
>>>CLOCK_SPEED
>>>after the TBR configuration, but I would like to know what is
>>>triggering the
>>>overwriting of the trap table.
>>>Did somebody already find this problem using RTEMS with ERC32 (the
>>>real one,
>>>not the simulator)?
>>If you get a chance, I would like the output of at least a few of the
>>tmtests on real hardware at a known clock speed to compare to the
>>simulator.  That was what I was trying to look at today on the simulator
>>but became uncertain that the numbers reported were right.  I need a
>>sanity check against real hardware. :)
>>>Thanks in advance and best regards,
>>>Fabrício de Novaes Kucinskis - DEA / INPE
>>>Divisão de Eletrônica Aeroespacial
>>>Instituto Nacional de Pesquisas Espaciais
