4.6.4 build problems.
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Mon Sep 12 13:40:51 UTC 2005
rtwas wrote:
> Hello,
> I have'nt built an RTEMS dist in a while so I always wonder how I'm
> gonna screw up.
> But this error does'nt seem to be about me:
> checking whether build environment is sane... configure: error: newly
> created file is older than distributed files!
> Check your system clock
> configure: error: /bin/sh
> '../../../../../rtems-4.6.4/c/src/libnetworking/configure' failed for
> libnetworking
> gmake[2]: [dmv177] Error 1 (ignored)
> Configuring RTEMS_BSP=dmv177
> '../../../../../rtems-4.6.4/c/src/make/configure' failed for make
> gmake[2]: [gen405] Error 1 (ignored)
> The config was setup to build the powerpc targets:
> ../rtems-4.6.4/configure --target=powerpc-rtems
You probably want to add a --enable-rtemsbsp=XXX option to significantly
speed up the build and reduce the disk space required.  You can't
possibly want to build every powerpc BSP. :)
> then a "gmake all"
> I tried a "gmake -i all" and it just loops.
> I'm running rh9 btw with the prebuilt tools provided in the 4.6.4
> release page (for powerpc).
> Robert W.
