Multiple definition of '__assert'
Camilo Alejandro Arboleda
camilo.arboleda at spymac.com
Mon Sep 12 17:46:45 UTC 2005
Looking at BSP sources, there is only one call to assert (in ne2000
driver), I'm going to try your recomendation and tell you the results.
I don't know the linker internals, so there is a question that rise: Why
does it works when I put console.c in my project?
Till Straumann escribió:
> Camilo Alejandro Arboleda wrote:
>> Hello,
>> I worte to the list because of this problem, but there is no answer
>> (yet).
>> I'm using rtems 4.6.2, with gcc 3.2.3 and newlib 1.1.13. When I try
>> to compile even a simple application agaist pc486 BSP I get an error
>> message telling there is a previous definition of __assert. My
>> work-around was to copy console.c to my project directory, and
>> compiling it as part of my project.
>> Has anybody the same problem?
> Yes. This is a bug. You should file a PR (after double-checking that
> no one
> exists already). The PCx86 BSP provides its own version of __assert
> although
> another implementation already comes with libc. The BSP's version
> (among other
> things) uses 'printk' instead of 'printf' so that assert can be used
> from ISR context.
> My suggested fix would be eliminating the BSP-specific implementation
> from
> console.c and removing 'assert' statements from interrupt handlers
> (pcx86 BSP).
> HTH
> -- Till
>> Any ideas or a cleaner work-around?
>> The test program is
>> | /* confdefs.h. */
>> | #define PACKAGE_NAME ""
>> | #define PACKAGE_TARNAME ""
>> | #define PACKAGE_VERSION ""
>> | #define PACKAGE_STRING ""
>> | #define PACKAGE_BUGREPORT ""
>> | /* end confdefs.h. */
>> | int
>> | main ()
>> | return 0;
>> and the error is:
>> /usr/rtems-4.6/i386-rtems/pc486/lib/librtemsbsp.a(console.o): In
>> function `__assert':
>> /cygdrive/c/rtems/build-rtems/i386-rtems-4.6.2/i386-rtems/c/pc486/lib/libbsp/i386/pc386/console/../../../../../../../../../../rtems-4.6.2/c/src/lib/libbsp/i386/pc386/console/console.c:151:
>> multiple definition of `__assert'
>> /cygdrive/c/cygwin/usr/rtems/i386-rtems/bin/../lib/gcc-lib/i386-rtems/3.2.3/../../../../i386-rtems/lib/libc.a(assert.o):/cygdrive/c/rtems/build-utils/gcc_3.2.3-i386/i386-rtems/newlib/libc/stdlib/../../../../../../source/gcc-3.2.3/newlib/libc/stdlib/assert.c:56:
>> first defined here
>> /cygdrive/c/cygwin/usr/rtems/i386-rtems/bin/../lib/gcc-lib/i386-rtems/3.2.3/../../../../i386-rtems/bin/ld:
>> Warning: size of symbol `__assert' changed from 41 to 133 in
