PR469 IDE problem, was: Re: Any New 4.6.4 Issues
Angelo Fraietta
newsgroups at smartcontroller.com.au
Thu Sep 15 22:18:11 UTC 2005
I will do this today, however, I need some help
Thomas Doerfler (nt) wrote:
> Would you apply the attached patch to your RTEMS source tree and perform
> a "bootstrap" to it?
I try this by doing ./bootstrap in the root of rtems4.6.4 (after
applying the patch) and get a swag of errors. I cancelled the bootstracp
and have attached the screen
> After bootstrapping, you will have two options in the pc386 BSP:
> - - the option IDE_USE_PRIMARY_INTERFACE is enabled by default, you should
> disable it (set it to 0)
> - - the option IDE_USE_SECONDARY_INTERFACE is disabled by default, you
> should enable it (set it to 1)
I will end up running 2 different BSPs - pc386dx (for DIMMPC which has
primary) and pc386 (which only has secondary). Will this be a problem?
For the time being, I suppose I can build my pc386dx version before
applying the patch and then the pc386 after
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.smartcontroller.com.au/~angelo/
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
An embedded and charset-unspecified text was scrubbed...
Name: Saved Terminal Output.txt
URL: <http://lists.rtems.org/pipermail/users/attachments/20050916/aee35296/attachment-0001.txt>
