PR469 IDE problem, was: Re: Any New 4.6.4 Issues
Ralf Corsepius
ralf.corsepius at rtems.org
Fri Sep 16 06:05:12 UTC 2005
On Fri, 2005-09-16 at 07:12 +0200, Thomas Doerfler (nt) wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Angelo,
> > The file I see is called bspopts.h.in
> > The two defines are both undef'd
> > I place the definitions below them
> the file "c/src/lib/libbsp/i386/pc386/include/bspopts.h.in" is available
> in the source tree and will be converted (according to some specific
> definitions in configure.ac) to
> "<build-dir>\i386-rtems\c\pc386\lib\libbsp\i386\pc386\include\bspopt.h"
> in your build tree when you "configure" your build tree. In some very
> magic automake/autoconf process (sorry Ralf) the standard settings
> defined will be inserted there as "#define". And in your situation, you
> will not need the standard settings, but you have to disable the option
> IDE_USE_PRIMARY_INTERFACE and enable the option IDE_USE_SECONDARY_INTERFACE.
> I would do these changes in the created "bspopt.h"
No, you want to extend your BSP's configure.ac
> Ralf, I would assume that there is a better way to set these options,
> e.g. when "configure" is given. I added definitions for these options in
> the bsp's "configure.ac" file, so I assume there is a predefined way to
> modify these options....
I don't understand.
Ralf
