PR469 IDE problem, was: Re: Any New 4.6.4 Issues
Thomas Doerfler (nt)
Thomas.Doerfler at imd-systems.de
Fri Sep 16 07:53:03 UTC 2005
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Ralf,
many thanks for making these things clear to me.
Ralf Corsepius schrieb:
> On Fri, 2005-09-16 at 08:42 +0200, Thomas Doerfler (nt) wrote:
>>E.g. Angelo's hardware will require these settings:
>>#define IDE_USE_PRIMARY_INTERFACE 0
>>#define IDE_USE_SECONDARY_INTERFACE 1
> => he wants "non-default settings".
> This means he will want to explicitly override them.
> As things currently are implemented, he should be able to so by
> overriding them from the environment:
> ../configure --enable-rtemsbsp=pc386 \
> --target=i386-rtems4.7 \
> --prefix=<whatever> \
> IDE_USE_PRIMARY_INTERFACE=1 \
> IDE_USE_SECONDARY_INTERFACE=0
HURRAY, that's what I was expecting (but didn't know the details).
But I think there is a typo, the options are set the wrong way round. It
should be:
- --target=i386-rtems4.7 \
- --prefix=<whatever> \
IDE_USE_PRIMARY_INTERFACE=0 \
IDE_USE_SECONDARY_INTERFACE=1
> BTW: Shouldn't these options be mutually exclusive or be integer values.
> (IDE_INTERFACE={0,1,2} or similar).
No, with the way I defined these options, you can also have a RTEMS
system with TWO interfaces and FOUR disks (it the ATA driver can handle
this, I never tried)
> You ain't ;)
So now I should stop working and start the weekend, because the rest of
Friday can only get worse :-)
Thanks again, Ralf.
Angelo, can you try this out?
wkr,
Thomas.
> Ralf
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at:
http://www.imd-systems.de/pgpkey_en.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.5 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDKnnewHyg4bDtfjQRAhHEAJ99pAGgC2g8ozdYoxVzpN41cwkwLQCZAcfD
GOiPJ+HamSVbYpG1QLjZZiU=
=qqeg
-----END PGP SIGNATURE-----
