mvme2600/4 motorola_bsp: Anyway doing work on this bsp?
rtwas
rtwas at comcast.net
Sun Sep 25 16:40:19 UTC 2005
Till Straumann wrote:
>> Network PReP-Boot Mode Enable [Y/N] = N?
> One thing - I believe the (admittedly well hidden
> c/src/lib/libbsp/powerpc/motorola_powerpc/BOOTING
> file -- I had a hard time figuring this out a couple of
> years ago and I agree that this is not first-time user
> friendly) says that you have to enable PreP mode
> Network PReP-Boot Mode Enable [Y/N] = Y? <====================
> HTH
> --Till
I made the change specified and...
PPC1-Bug>nbo
Network Booting from: DEC21140, Controller 0, Device 0
Device Name: /pci at 80000000/pci1011,9 at e,0:0,0
Loading: 2604-0.boot
Client IP Address = 192.168.1.61
Server IP Address = 192.168.1.60
Gateway IP Address = 192.168.1.60
Subnet IP Address Mask = 255.255.255.0
Boot File Name = 2604-0.boot
Argument File Name =
Network Boot File load in progress... To abort hit <BREAK>
Bytes Received =&153644, Bytes Loaded =&153644
Bytes/Second =&76822, Elapsed Time =2 Second(s)
Residual-Data Located at: $01F78000
M
B
T
M
H
Model: 000000000000000000000000000(e2)
Serial: MOT0325F15
Processor/Bus frequencies (Hz): 199922336/66636112
Time Base Divisor: 4000
Memory Size: 2000000
Original MSR: 3040
Original HID0: 80
Original R31: 0
PCI: Probing PCI hardware
RTEMS 4.x/PPC load:
Uncompressing the kernel...
Kernel at 0x00000000, size=0x36f60
Initrd at 0x00000000, size=0x0
Residual data at 0x00037000
Command line at 0x0003e000
done
Now booting...
Welcome to rtems-4.6.2(PowerPC/PowerPC 604/mvme2307) on MVME 2600 with
MVME712M
OpenPIC found at C1000000.
pci : Interrupt routing not available for this bsp
OpenPIC Version 1.2 (2 CPUs and 17 IRQ sources) at 0xC1000000
OpenPIC Vendor 0 (Motorola), Device 0 (Raven), Stepping 1
OpenPIC timer frequency is 8329514 Hz
Please add code for PCI/ISA bridge init to
libbsp/powerpc/shared/irq/irq_init.c
If your card works correctly please add a test and set
known_cpi_isa_bridge to e
currentBoard = 15
Universe II PCI-VME bridge detected at 0xC1041000, IRQ 11
Universe Master Ports:
Port VME-Addr Size PCI-Adrs Mode:
0: 0x20000000 0x0F000000 0x10000000 A32, Dat, Sup
1: 0x00000000 0x00FF0000 0x1F000000 A24, Dat, Sup
2: 0x00000000 0x00010000 0x1FFF0000 A16, Dat, Sup
Universe Slave Ports:
0: 0xC0000000 0x01FE0000 0x80000000 A32, Pgm, Dat, Sup, Usr
Overriding main IRQ line PCI info with 5
)egistering /dev/console as minor 0 (==/dev/ttyS0)
*** HELLO WORLD TEST ***
Hello World
*** END OF HELLO WORLD TEST ***
..Robert does a happy dance..
Thank you very much. :)
Robert W.
