Building RTEMS without test samples
Ralf Corsepius ralf.corsepius at rtems.org
Tue Sep 27 13:29:00 UTC 2005
On Tue, 2005-09-27 at 07:03 -0500, Joel Sherrill  wrote:
> Samuel Bitton wrote:
> > Do you have a proper work around to suggest please.
> > Although Leon Pollak says that the problem can be ignored as the library is built by the time the test suits starts being built, as far as I can tell, even if the BSP library is built, it is not installed in the final specified directory (i.e. /opt/rtems-4.6/i386-rtems/obc386) as this actually happens after the test suit compilation.
> One easy solution is to provide stubs for all the missing parts.
Well, IMO, the OP is trying to outsmart himself.
AFAIU, he seems to be trying to switch off the tests, which trigger
problems in his code instead to fix them.
Without seeing his code further commenting is impossible.
Ralf
