mvme2604 confidence test.
rtwas rtwas at comcast.net
Tue Sep 27 18:04:24 UTC 2005
Hello,
Joel Sherrill <joel at OARcorp.com> wrote:
> rtwas wrote:
>> Hello,
>> Well I finally was able to successfully operate a slave vme card
>> (vmic4100 in this case).
>> Thanks for all the help.
>> Should I post this (slave exercise code) as an example on the rtems
>> wiki?
> That would be very nice.  Is ticker working?
I could find no "ticker" demos in either "examples-4.6.2" or
"network-demos-4.6.2".
I did get "psx_sched_report" to work:
Welcome to rtems-4.6.2(PowerPC/PowerPC 604/mvme2307) on MVME 2600 with
MVME712M
OpenPIC found at C1000000.
pci : Interrupt routing not available for this bsp
OpenPIC Version 1.2 (2 CPUs and 17 IRQ sources) at 0xC1000000
OpenPIC Vendor 0 (Motorola), Device 0 (Raven), Stepping 1
OpenPIC timer frequency is 8329514 Hz
Please add code for PCI/ISA bridge init to
libbsp/powerpc/shared/irq/irq_init.c
If your card works correctly please add a test and set
known_cpi_isa_bridge to ecurrentBoard = 15
Universe II PCI-VME bridge detected at 0xC1041000, IRQ 11
Universe Master Ports:
Port  VME-Addr   Size       PCI-Adrs   Mode:
0:    0x20000000 0x0F000000 0x10000000 A32, Dat, Sup
1:    0x00000000 0x00FF0000 0x1F000000 A24, Dat, Sup
2:    0x00000000 0x00010000 0x1FFF0000 A16, Dat, Sup
Universe Slave Ports:
0:    0xC0000000 0x01FE0000 0x80000000 A32, Pgm, Dat, Sup, Usr
Overriding main IRQ line PCI info with 5
=Information on SCHED_OTHER minor 0 (==/dev/ttyS0)
         Supports 253 priority levels (1 - 254)
         Implementation is compliant on priority levels
         Scheduling quantum is 0 seconds and 1000000 nanoseconds
Information on SCHED_FIFO
Information on SCHED_RR
> What about netdemo?
No joy here. I'm not entirely sure I've configured "networkconfig.h"
correctly.
I've attached the subdirectory and console log to this post.
***mail list sever kicked it back cause my attachment was too big**
Question: What does this mean "pci : Interrupt routing not available for
this bsp"?
Robert W.
