Queue Urgent question
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Thu Sep 29 15:12:49 UTC 2005
leonp at plris.com wrote:
> Hello, all.
> Stupid question: I have FIFO queue (for 100 messages) which contains, let's
> say, 2 messages m1 and m2 in it (receiving task is suspended). Then I do
> rtems_message_queue_urgent(m3 ...) and resume the receiving task.
> I expected the m3 message to arrive the first, but I see the sequence
> m1, m2, m3.
Without looking at code, if the receiving task is blocked on the
queue_receive, then when m1 is sent, it is immediately given to the
task and not enqueued. Even if the receiver is suspended.
From your description, I can't tell why the other two would not
show up in m3, m2 unless it is running or there are multiple receivers.
Given your description and assuming no other receivers:
- m1 directly to receiver
- m2 should be enqueued as only message pending
- m3 should be prepended to pending messages
Do you have a small test case?
> Any hint will be highly appreciated.
> My rtems is rtems-ss-20030703.
This code would not have changed since then. :)
joel at OARcorp.com On-Line Applications Research
