RES: RES: Problem when trying to build hello_world_c: more info
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Thu Sep 29 18:01:46 UTC 2005
Fabrício de Novaes Kucinskis wrote:
> Joel,
> You were right. It's my mistake, this is a documented issue. I'm sorry for
> ask so fool question!
No problem. Everyone starts as a beginner. And that is important to
improving RTEMS and other open source software. Since you are new, you
see things in a different light. So when you see something you don't
quite get in the documentation, suggest improvements. :)
> Thank you very much,
No problem.
--joel
> Fabrício.
> -----Mensagem original-----
> De: Joel Sherrill <joel at OARcorp.com> [mailto:joel.sherrill at OARcorp.com]
> Enviada em: quinta-feira, 29 de setembro de 2005 10:27
> Para: Fabrício de Novaes Kucinskis
> Cc: RTEMS - Mailing List
> Assunto: Re: RES: Problem when trying to build hello_world_c: more info
>>Hi again,
>>I have more information about the problem. I'm almost sure the problem is
> in
>>the RTEMS build process. After "configure", I ran a "gmake all install"
>>command. The build process took some minutes, and ended with an error:
>> gmake install-data-hook
>> gmake[6]: Entering directory
> `/opt/tharsys/sparc-rtems/c/erc32/exec/wrapup'
>> /usr/bin/install -c -m 644 ../../../../erc32/lib/librtemscpu.a
>>/opt/tharsys/sparc-rtems/erc32/lib
>> /usr/bin/install: `../../../../erc32/lib/librtemscpu.a' and
>> `/opt/tharsys/sparc-rtems/erc32/lib/librtemscpu.a' are the same file
>> gmake[6]: ** [install-data-hook] Error 1
>> gmake[6]: Leaving directory
>> gmake[5]: ** [install-data-am] Error 2
>> gmake[5]: Leaving directory
>> gmake[4]: ** [install-am] Error 2
>> gmake[4]: Leaving directory
>> gmake[3]: ** [install-recursive] Error 1
>> gmake[3]: Leaving directory `/opt/tharsys/sparc-rtems/c/erc32/exec'
>> gmake[2]: ** [install-recursive] Error 1
>> gmake[2]: Leaving directory `/opt/tharsys/sparc-rtems/c/erc32'
>> gmake[1]: ** [install-recursive] Error 1
>> gmake[1]: Leaving directory `/opt/tharsys/sparc-rtems/c'
>> gmake: ** [install-recursive] Error 1
> My guess is that you are building in the install point. That will not
> work for RTEMS or most other GNU autoconf packages. Build somewhere
> else in the filesystem.
>>I didn't notice this error on the first time I installed RTEMS 4.6.4. When
>>trying to make the hello_world_c example, the gmake complain that there's
> no
>>Makefile.inc under RTEMS_MAKEFILE_PATH, which is right. So, my problem
>>appears to be on the RTEMS build, but I don't know where, or why.
>>Does anybody know how can I solve this problem?
>>Thanks again,
>>Fabrício.
>>De: Fabrício de Novaes Kucinskis [mailto:fabricio at dea.inpe.br]
>>Enviada em: terça-feira, 27 de setembro de 2005 16:28
>>Para: RTEMS - Mailing List
>>Assunto: Problem when trying to build hello_world_c
>>Hi all,
>>I was using RTEMS 4.0.0, and just upgraded to the 4.6.4 release. In the
>>4.0.0 version, I built applications using sparc-rtems-gcc with the
> "-rtems"
>>switch.
>>After install binutils, gcc, newlib, gdb, and build the RTEMS, I tried to
>>build a sample program (hello_world_c) to test the instalation, but I the
>>gcc compiler didn't recognized the "-rtems" switch. I found that it isn't
>>suported anymore.
>>So, I tried to use make, but got this error message:
>> Makefile:33: /Makefile.inc: No such file or directory
>> Makefile:35: no file name for `include'
>> Makefile:36: /make/leaf.cfg: No such file or directory
>> make: *** No rule to make target `/make/leaf.cfg'. Stop.
>>I'm sure that the RTEMS_MAKEFILE_PATH is pointing to the right directory.
>>What can be happening?
>>Thanks in advance,
>>Fabrício de Novaes Kucinskis - DEA / INPE
>>Divisão de Eletrônica Aeroespacial
>>Instituto Nacional de Pesquisas Espaciais
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
