Problem to save file on the hard disk! What I have to set to do it ?
Angelo Fraietta newsgroups at smartcontroller.com.au
Wed Apr 5 02:21:37 UTC 2006
I used GCC version gcc-3.2.3
I did not use RPMs - I followed exactly as shown in
http://www.smartcontroller.com.au/~angelo/thesisCD
I have also included instructions for Cygwin and all the source is
provided to build RTEMS and the tools +  Cygwin
Yan Luo wrote:
> Hello Angelo,
> Could you please let me know the gcc version you are using? Did you
> install gcc from the RPM or source code ?
> I am able to use another laptop and init partition table. but i still
> face a strange problem: fileio hangs when read files.
> Thanks.
> On Mar 16, 2006, at 5:42 PM, Angelo Fraietta wrote
>> Yan Luo wrote:
>>>> Hm, this sounds, as if reading of the partition table hangs. What  kind
>>>> of interface do you have to connect your harddisk? RTEMS  currently
>>>> only
>>>> supports a standard IDE interface (no SCSI, no SATA...). And it
>>>> asumes,
>>>> that the harddisk is connected as Master to the primary IDE
>>>> interface. I
>>>> should have mentioned this before :-(
>>> I am using a pretty old laptop (Compaq, Pentium, no CDROM). I
>>> believe  the hard drive is standard IDE based and on primary  master
>>> because it  is "hda" in Debian linux. It would have other  device
>>> names if it were  SCSI or other, right?
>>> I am wondering if "grub" (the boot loader) caused the problems.
>>> Both  Matteo and I use grub. Will grub affect the partition table
>>> and  mounting? Could you tell us the test environment that you run
>>> fileio  on before, if you don't use grub or lilo?
>> I used grub on a hard drive and had no problems.
>> Try running DOS FDISK and have a look at what the partitions look  like.
>> Angelo Fraietta
>> PO Box 859
>> Hamilton NSW 2303
>> Home Page
>> There are those who seek knowledge for the sake of knowledge - that
>> is CURIOSITY
>> There are those who seek knowledge to be known by others - that is
>> VANITY
>> There are those who seek knowledge in order to serve - that is LOVE
>>     Bernard of Clairvaux (1090 - 1153)
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
